A Guide to VB .NET Cryptography
Found here!
The Requirements for .NET Cryptography
To tap into the .NET security features, you need Imports statements and encryption packs. First, to experiment with any of the code in this article, be sure that you add the following Imports statements at the top of your Visual Basic code window:
Imports System.IO
Imports System.Text
Imports System.Security.Cryptography
Second, note that the U.S. government restricted encryption in the past to prevent certain encryption technology from being exported. Although the restrictions are no longer in effect, the .NET framework prohibits “strong” or “high” encryption in export versions of the Windows OS. If you don’t already have strong encryption capabilities in your version of Windows, you can download an update on the Microsoft Web site. Install the High Encryption Pack included in Service Pack 2 for Windows 2000, or Service Pack 6a for NT. Internet Explorer 5.5 also includes the High Encryption Pack for users of Windows ME, 95, and 98.
Here’s the code for the encryption/decryption utility. It surrounds the encryption, decryption, and key-generating procedures with some user interface conveniences. It provides a TextBox into which the user types a filename and another TextBox to type in the key.
Imports System.IO
Imports System.Text
Public Class Form1
Inherits System.Windows.Forms.Form
   'create an 8-byte long array to hold the key
    Public  TheKey(7)  As   Byte
   'Stuff some random values into the vector:
    Private  Vector()  As   Byte  = {&H12, &H44, &H16, &HEE, &H88, &H15, &HDD, &H41}
   'Windows Form Designer generated code
   '/////ENCRYPTION PROCEDURE
    Sub  Encrypt( ByVal  inName  As   String ,  ByVal  outName  As   String )
            Dim  storage(4096)  As   Byte   'create buffer
            Dim  totalBytesWritten  As   Long  = 8  'Keeps track of bytes written.
            Dim  packageSize  As   Integer   'Specifies the number of bytes written at one time.
           'Declare the file streams.
            Dim  fin  As   New  FileStream(inName, FileMode.Open, FileAccess.Read)
            Dim  fout  As   New  FileStream(outName, FileMode.OpenOrCreate, _
              FileAccess.Write)
           fout.SetLength(0)
            Dim  totalFileLength  As   Long  = fin.Length  'Specifies the size of the source file.
           'create the Crypto object
              Dim  des  As   New  DESCryptoServiceProvider()
            Dim  crStream  As   New  CryptoStream(fout, _
                   des.CreateEncryptor(TheKey, Vector), CryptoStreamMode.Write)
           'flow the streams
            While  totalBytesWritten < totalFileLength
               packageSize = fin.Read(storage, 0, 4096)
               crStream.Write(storage, 0, packageSize)
               totalBytesWritten = Convert.ToInt32(totalBytesWritten + packageSize / des.BlockSize * des.BlockSize)
              End   While
           crStream.Close()
        Catch  e  As  Exception
           MsgBox(e.Message)
        End   Try
    End   Sub
   '//////// DECRYPTION PROCEDURE
   ' This procedure differs from the encryption procedure only in the substitution of
   'des.CreateDecryptor for des.CreateEncryptor. Also, the error message is different.
    Sub  Decrypt( ByVal  inName  As   String ,  ByVal  outName  As   String )
              FileAccess.Write)
           fout.SetLength(0)
              des.CreateDecryptor(TheKey, Vector), CryptoStreamMode.Write)
            Dim  ex  As  Exception
               Console.WriteLine("Processed {0} bytes, {1} bytes total", packageSize, _
                  totalBytesWritten)
            End   While
           crStream.Close()
             MsgBox(e.Message & "Please ensure that you are using the correct password")
        End   Try
    End   Sub
   'BROWSE BUTTON
    Private   Sub  Button1_Click( ByVal  sender  As  System.Object,  ByVal  e  As  System.EventArgs)  Handles  Button1.Click
       OpenFileDialog1.ShowDialog()
       TextBox1.Text = OpenFileDialog1.FileName
    End   Sub
   'ENCRYPT/DECRYPT BUTTON
    Private   Sub  Button2_Click( ByVal  sender  As  System.Object,  ByVal  e  As  System.EventArgs)  Handles  Button2.Click
        Dim  targetfile, sourcefile  As   String
       'check to see if they've entered a filename at all
        If  TextBox1.Text = ""  Or  TextBox2.Text = ""  Then  MsgBox("You must enter a filename and a password.") :  Exit  Sub
       'check to see if it is a decryption (the filename ends in "xx")
        Dim  ext  As   String   'file extension
        Dim  mainpath  As   String   'the file path minus the extension
        Dim  n  As   Integer   'location of period in filepath
       n = TextBox1.Text.IndexOf(".")  ' returns -1 if there is no extension
        If  n <> -1  Then   'extract the extension
           ext = TextBox1.Text.Substring(n + 1)
           mainpath = TextBox1.Text.Substring(0, TextBox1.Text.Length - ext.Length - 1)
        End   If
       'check for "xx" at the end of the filename, indicating an already encrypted file:
        If  mainpath.Substring(mainpath.Length - 2) = "xx"  Then   'this file will be decrypted
           'DECRYPT:
           sourcefile = TextBox1.Text
             'compose filepath by removing the "xx":
           mainpath = mainpath.Substring(0, mainpath.Length - 2)
            If  ext <> ""  Then  mainpath &= "." & ext
           targetfile = mainpath
           CreateKey(TextBox2.Text)  'create the key
           Decrypt(sourcefile, targetfile)
           Label3.Text = "Finished decryption..."
            Exit   Sub
        End   If
       'ENCRYPT
       'there was no "xx" appended, so they must be encrypting a file
       'compose the encrypted file's filepath by appending "xx":
       mainpath &= "xx"
       Encrypt(sourcefile, targetfile)
       Label3.Text = "Finished encryption..."
    End   Sub
   '////// Procedure that hashes the password and creates a key
    Sub  CreateKey( ByVal  strKey  As   String )
       ' Byte array to hold key
        Dim  arrByte(7)  As   Byte
        Dim  AscEncod  As   New  ASCIIEncoding()
        Dim  i  As   Integer  = 0
       AscEncod.GetBytes(strKey, i, strKey.Length, arrByte, i)
       'Get the hash value of the password
        Dim  hashSha  As   New  SHA1CryptoServiceProvider()
        Dim  arrHash()  As   Byte  = hashSha.ComputeHash(arrByte)
       'put the hash value into the key
        For  i = 0  To  7
           TheKey(i) = arrHash(i)
        Next  i
    End   Sub
End Class
