Another System.Security.Cryptography Example
Here is an example:
Public Class Cryptions
' Var
Private m_InitVecKey As String = "smooth" 'chose your own default Key and Passwords
Private m_PasswordKey As String = "pussy"
Private m_InputFile As String 'Use full drive/path/file names
Private m_OutputFile As String
Private Enum CryptoAction
    actionEncrypt = 1
    actionDecrypt = 2
End Enum
' Property
Public Property FileInput()
    Get
    End Get
    Set(ByVal Value)
        m_InputFile = Value
    End Set
End Property
Public Property FileOutput()
    Get
    End Get
    Set(ByVal Value)
        m_OutputFile = Value
    End Set
End Property
Public Property Key() 'if you change from your defaults remember them!
    Get
        Key = GetKeyByteArray(m_PasswordKey)
    End Get
    Set(ByVal Value)
        m_PasswordKey = Value
    End Set
End Property
Public Property IntiKey() 'if you change from your defaults remember them!
    Get
        IntiKey = GetKeyByteArray(m_InitVecKey)
    End Get
    Set(ByVal Value)
        m_InitVecKey = Value
    End Set
End Property
' Event
' Methods
'encrypt file
Public Function EncryptFile()
    EncryptOrDecryptFile(CryptoAction.actionEncrypt)
End Function
Public Function DecryptFile()
    EncryptOrDecryptFile(CryptoAction.actionDecrypt)
End Function
Private Function GetKeyByteArray(ByVal sPassword As String) As Byte()
    Dim byteTemp(7) As Byte
    sPassword = sPassword.PadRight(8) ' make sure we have 8 chars
    Dim iCharIndex As Integer
    For iCharIndex = 0 To 7
        byteTemp(iCharIndex) = Asc(Mid$(sPassword, iCharIndex + 1, 1))
    Next
    Return byteTemp
End Function
Private Sub EncryptOrDecryptFile(ByVal Direction As CryptoAction)
    'Create the file streams to handle the input and output files.
    Dim fsInput As New System.IO.FileStream(m_InputFile, System.IO.FileMode.Open, System.IO.FileAccess.Read)
    Dim fsOutput As New System.IO.FileStream(m_OutputFile, System.IO.FileMode.OpenOrCreate, System.IO.FileAccess.Write)
    fsOutput.SetLength(0)
    'Variables needed during encrypt/decrypt process
    Dim byteBuffer(4096) As Byte 'holds a block of bytes for processing
    Dim nBytesProcessed As Long = 0 'running count of bytes encrypted
    Dim nFileLength As Long = fsInput.Length
    Dim iBytesInCurrentBlock As Integer
    Dim desProvider As New System.Security.Cryptography.DESCryptoServiceProvider()
    Dim csMyCryptoStream As System.Security.Cryptography.CryptoStream
    ' Set up for encryption or decryption
    Select Case Direction
        Case CryptoAction.actionEncrypt
            csMyCryptoStream = New System.Security.Cryptography.CryptoStream(fsOutput, desProvider.CreateEncryptor(Key, IntiKey), System.Security.Cryptography.CryptoStreamMode.Write)
        Case CryptoAction.actionDecrypt
            csMyCryptoStream = New System.Security.Cryptography.CryptoStream(fsOutput, desProvider.CreateDecryptor(Key, IntiKey), System.Security.Cryptography.CryptoStreamMode.Write)
    End Select
    'Read from the input file, then encrypt or decrypt and write to the output file.
    While nBytesProcessed < nFileLength
        iBytesInCurrentBlock = fsInput.Read(byteBuffer, 0, 4096)
        csMyCryptoStream.Write(byteBuffer, 0, iBytesInCurrentBlock)
        nBytesProcessed = nBytesProcessed + CLng(iBytesInCurrentBlock)
    End While
    csMyCryptoStream.Close()
    fsInput.Close()
    fsOutput.Close()
End Class
