C a t c h M o d i f i e r K e y s
By Michael McIntyre
You can monitor key strokes to catch the SHIFT, CTRL, or ALT modifier keys. When a modifier key is pressed in combination with other keys the information is provided in the System.Windows.Forms.KeyEventArgs passed to a KeyDown event handler method.
Examples:
’ Catch SHIFT + A key strokes.
If e.KeyCode = Keys.A And (e.Shift And Not e.Control And Not e.Alt) Then
MessageBox.Show(“Pressed: SHIFT + A”)
’ Catch CONTROL + A key strokes.
If e.KeyCode = Keys.A And (Not e.Shift And e.Control And Not e.Alt) Then
MessageBox.Show(“Pressed: CONTROL + A”)
’ Catch ALT + A key strokes.
If e.KeyCode = Keys.A And (Not e.Shift And Not e.Control And e.Alt) Then
MessageBox.Show(“Pressed: ALT + A”)
’ Catch SHIFT + CONTROL + A key strokes.
If e.KeyCode = Keys.A And (e.Shift And e.Control And Not e.Alt) Then
MessageBox.Show(“Pressed: SHIFT + CONTROL + A”)
’ Catch SHIFT + CONTROL + ALT + A key strokes.
If e.KeyCode = Keys.A And (e.Shift And e.Control And e.Alt) Then
MessageBox.Show(“Pressed: SHIFT + CONTROL + ALT + A”)
To Test: Use Visual Studio.Net to create a VB.NET Win Forms application. Add a TextBox control to Form1. Add a KeyDown handler for the TextBox. Add the sample code to the KeyDown handler. Start the application.
In the TextBox try these key strokes.
Hold down the SHIFT key and type: A
Hold down the CONTROL key and type: A
Hold down the ALT key and type: A
Hold down the SHIFT and CONTROL keys and type: A
Hold down the SHIFT and CONTROL and ALT keys and type: A
