Insert Into Command
Here is and example using and input box
Private Sub mnuAdd_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles mnuAdd.Click
        Dim DateAdded As Date
        Dim SiteName, Username, Pass As String
        Dim dbNewRow As DataRow = dsSites.Tables(0).NewRow
        DateAdded = Date.Now.ToShortDateString ' Date Added
        SiteName = InputBox("Site Name:", "Site Name") ' Site Name
        Username = InputBox("Username:", "Username") ' Username
        Pass = InputBox("Pass:", "Pass") ' Pass
        dbNewRow("SiteID") = dsSites.Tables(0).Rows.Count() + 1
        dbNewRow("DateAdded") = DateAdded
        dbNewRow("SiteName") = SiteName
        dbNewRow("Username") = Username
        dbNewRow("Pass") = Pass
        Dim SQL As String
        SQL = "INSERT INTO Sites (DateAdded, SiteName, Username, Pass) "
        SQL = SQL & "VALUES ("
        SQL = SQL & DateAdded & ", "
        SQL = SQL & SiteName & ", "
        SQL = SQL & Username & ", "
        SQL = SQL & Pass & ")"
        Dim dbCommand As OleDb.OleDbCommand = New OleDb.OleDbCommand(SQL, dbConnection)
        dbAdapter.InsertCommand = dbCommand
        dsSites.Tables(0).Rows.Add(dbNewRow)
            dbAdapter.Update(dsSites)        <--- Err here
        Catch ex As Exception
            MsgBox("Error: " & ex.Message)
            Exit Sub
        Debug.WriteLine("Insert Command: " & dbAdapter.InsertCommand.CommandText.ToString & vbCrLf)
        lblMessage.Text = "Entry Successfully Added."
        lstSites.Items.Clear() ' Clear the listbox
        Login() ' Refresh the listbox
