Setting DataGridView ColumnType programmatically
The following code may be of use, its straight from MS Help.
Visual Basic
Dim dataGridViewComboBoxColumn1 As New DataGridViewComboBoxColumn()
Syntax
Visual Basic
Public Class DataGridViewComboBoxColumn
    Inherits DataGridViewColumn
Example
The following code example demonstrates how to use a DataGridViewComboBoxColumn to aid in entering data into the Title column.
Visual Basic Copy Code
Imports System
Imports System.Data
Imports System.Data.SqlClient
Imports System.Windows.Forms
Imports System.Collections.Generic
Imports System.Drawing
Public Class Employees
    Inherits System.Windows.Forms.Form
    Private WithEvents DataGridView1 As New DataGridView
    Private WithEvents DataGridView2 As New DataGridView
    <STAThreadAttribute()> _
    Public Shared Sub Main()
            Application.EnableVisualStyles()
            Application.Run(New Employees())
        Catch e As Exception
            MessageBox.Show(e.Message & e.StackTrace)
    Private Sub Form1_Load(ByVal sender As System.Object, _
        ByVal e As System.EventArgs) Handles MyBase.Load
            SetUpForm()
            SetUpDataGridView1()
            SetUpDataGridView2()
        Catch ex As SqlException
            MessageBox.Show("The connection string <" _
                & connectionString _
                & "> failed to connect. Modify it to connect to " _
                & "a Northwind database accessible to your system.", _
                "ERROR", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Application.Exit()
    Private Sub SetUpForm()
        Size = New Size(800, 600)
        Dim flowLayout As New FlowLayoutPanel()
        flowLayout.FlowDirection = FlowDirection.TopDown
        flowLayout.Dock = DockStyle.Fill
        Controls.Add(flowLayout)
        Text = "DataGridView columns demo"
        flowLayout.Controls.Add(DataGridView1)
        flowLayout.Controls.Add(DataGridView2)
    Private Sub SetUpDataGridView2()
        DataGridView2.Dock = DockStyle.Bottom
        DataGridView2.TopLeftHeaderCell.Value = "Sales Details"
        DataGridView2.RowHeadersWidthSizeMode = _
        DataGridViewRowHeadersWidthSizeMode.AutoSizeToAllHeaders
    Private Sub SetUpDataGridView1()
        ' Virtual mode is turned on so that the
        ' unbound DataGridViewCheckBoxColumn will
        ' keep its state when the bound columns are
        ' sorted.
        DataGridView1.VirtualMode = True
        DataGridView1.AutoSize = True
        DataGridView1.DataSource = _
            Populate("SELECT * FROM Employees")
        DataGridView1.TopLeftHeaderCell.Value = "Employees"
        DataGridView1.RowHeadersWidthSizeMode = _
        DataGridView1.ColumnHeadersHeightSizeMode = _
            DataGridViewColumnHeadersHeightSizeMode.AutoSize
        DataGridView1.AutoSizeColumnsMode = _
            DataGridViewAutoSizeColumnsMode.AllCells
        DataGridView1.AllowUserToAddRows = False
        DataGridView1.AllowUserToDeleteRows = False
        ' The below autogenerated column is removed so
        ' a DataGridViewComboboxColumn could be used instead.
        DataGridView1.Columns.Remove( _
            ColumnName.TitleOfCourtesy.ToString())
        DataGridView1.Columns.Remove(ColumnName.ReportsTo.ToString())
        AddLinkColumn()
        AddComboBoxColumns()
        AddButtonColumn()
        AddOutOfOfficeColumn()
    ' Using an enum provides some abstraction between column index
    ' and column name along with compile time checking, and gives
    ' a handy place to store the column names.
    Enum ColumnName
        EmployeeId
        LastName
        FirstName
        Title
        TitleOfCourtesy
        BirthDate
        HireDate
        Address
        City
        Region
        PostalCode
        Country
        HomePhone
        Extension
        Notes
        ReportsTo
        PhotoPath
        OutOfOffice
    End Enum
    Private Sub AddComboBoxColumns()
        Dim comboboxColumn As New DataGridViewComboBoxColumn()
        comboboxColumn = CreateComboBoxColumn()
        SetAlternateChoicesUsingDataSource(comboboxColumn)
        comboboxColumn.HeaderText = _
            "TitleOfCourtesy (via DataSource property)"
        DataGridView1.Columns.Insert(0, comboboxColumn)
        SetAlternateChoicesUsingItems(comboboxColumn)
            "TitleOfCourtesy (via Items property)"
        ' Tack this example column onto the end.
        DataGridView1.Columns.Add(comboboxColumn)
    Private Sub AddLinkColumn()
        Dim links As New DataGridViewLinkColumn()
        With links
            .HeaderText = ColumnName.ReportsTo.ToString()
            .DataPropertyName = ColumnName.ReportsTo.ToString()
            .ActiveLinkColor = Color.White
            .LinkBehavior = LinkBehavior.SystemDefault
            .LinkColor = Color.Blue
            .TrackVisitedState = True
            .VisitedLinkColor = Color.YellowGreen
        End With
        DataGridView1.Columns.Add(links)
    Private Shared Sub SetAlternateChoicesUsingItems( _
        ByRef comboboxColumn As DataGridViewComboBoxColumn)
        With comboboxColumn
            .Items.AddRange(New String() _
                    {"Mr.", "Ms.", "Mrs.", "Dr."})
        End With
    Private Function CreateComboBoxColumn() _
        Dim column As New DataGridViewComboBoxColumn()
        With column
            .DataPropertyName = ColumnName.TitleOfCourtesy.ToString()
            .HeaderText = ColumnName.TitleOfCourtesy.ToString()
            .DropDownWidth = 160
            .Width = 90
            .MaxDropDownItems = 3
            .FlatStyle = FlatStyle.Flat
        End With
        Return column
    End Function
    Private Sub SetAlternateChoicesUsingDataSource( _
        With comboboxColumn
            .DataSource = RetrieveAlternativeTitles()
            .ValueMember = ColumnName.TitleOfCourtesy.ToString()
            .DisplayMember = .ValueMember
        End With
    Private Function RetrieveAlternativeTitles() As DataTable
        Return Populate( _
            "SELECT distinct TitleOfCourtesy FROM Employees")
    End Function
    Private connectionString As String = _
            "Integrated Security=SSPI;Persist Security Info=False;" _
            & "Initial Catalog=Northwind;Data Source=localhost"
    Private Function Populate(ByVal sqlCommand As String) As DataTable
        Dim northwindConnection As New SqlConnection(connectionString)
        northwindConnection.Open()
        Dim command As New SqlCommand(sqlCommand, _
            northwindConnection)
        Dim adapter As New SqlDataAdapter()
        adapter.SelectCommand = command
        Dim table As New DataTable()
        table.Locale = System.Globalization.CultureInfo.InvariantCulture
        adapter.Fill(table)
        Return table
    End Function
    Private Sub AddButtonColumn()
        Dim buttons As New DataGridViewButtonColumn()
        With buttons
            .HeaderText = "Sales"
            .Text = "Sales"
            .UseColumnTextForButtonValue = True
            .AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells
            .FlatStyle = FlatStyle.Standard
            .CellTemplate.Style.BackColor = Color.Honeydew
            .DisplayIndex = 0
        End With
        DataGridView1.Columns.Add(buttons)
    Private Sub AddOutOfOfficeColumn()
        Dim column As New DataGridViewCheckBoxColumn()
        With column
            .HeaderText = ColumnName.OutOfOffice.ToString()
            .Name = ColumnName.OutOfOffice.ToString()
            .CellTemplate = New DataGridViewCheckBoxCell()
            .CellTemplate.Style.BackColor = Color.Beige
        End With
        DataGridView1.Columns.Insert(0, column)
    Private Sub PopulateSales( _
        ByVal buttonClick As DataGridViewCellEventArgs)
        Dim employeeId As String = _
            DataGridView1.Rows(buttonClick.RowIndex). _
            Cells(ColumnName.EmployeeId.ToString()).Value().ToString()
        DataGridView2.DataSource = Populate( _
            "SELECT * FROM Orders WHERE EmployeeId = " & employeeId)
#Region "SQL Error handling"
    Private Sub DataGridView1_DataError(ByVal sender As Object, _
    ByVal e As DataGridViewDataErrorEventArgs) _
    Handles DataGridView1.DataError
        MessageBox.Show("Error happened " _
            & e.Context.ToString())
        If (e.Context = DataGridViewDataErrorContexts.Commit) _
            Then
            MessageBox.Show("Commit error")
        If (e.Context = DataGridViewDataErrorContexts _
            .CurrentCellChange) Then
            MessageBox.Show("Cell change")
        If (e.Context = DataGridViewDataErrorContexts.Parsing) _
            Then
            MessageBox.Show("parsing error")
        If (e.Context = _
            DataGridViewDataErrorContexts.LeaveControl) Then
            MessageBox.Show("leave control error")
        If (TypeOf (e.Exception) Is ConstraintException) Then
            Dim view As DataGridView = CType(sender, DataGridView)
            view.Rows(e.RowIndex).ErrorText = "an error"
            view.Rows(e.RowIndex).Cells(e.ColumnIndex) _
            e.ThrowException = False
#End Region
    Private Sub DataGridView1_CellContentClick(ByVal sender As Object, _
        ByVal e As DataGridViewCellEventArgs) _
        Handles DataGridView1.CellContentClick
        If IsANonHeaderLinkCell(e) Then
            MoveToLinked(e)
        ElseIf IsANonHeaderButtonCell(e) Then
            PopulateSales(e)
    Private Sub MoveToLinked(ByVal e As DataGridViewCellEventArgs)
        Dim value As Object = DataGridView1.Rows(e.RowIndex). _
            Cells(e.ColumnIndex).Value
        If value.GetType Is GetType(DBNull) Then Return
        employeeId = CType(value, String)
        Dim boss As DataGridViewCell = _
            RetrieveSuperiorsLastNameCell(employeeId)
        If Not boss Is Nothing Then
            DataGridView1.CurrentCell = boss
    Private Function IsANonHeaderLinkCell(ByVal cellEvent As _
        DataGridViewCellEventArgs) As Boolean
        If TypeOf DataGridView1.Columns(cellEvent.ColumnIndex) _
            Is DataGridViewLinkColumn _
            AndAlso Not cellEvent.RowIndex = -1 Then _
            Return True Else Return False
    End Function
    Private Function IsANonHeaderButtonCell(ByVal cellEvent As _
            Is DataGridViewButtonColumn _
            Return True Else Return (False)
    End Function
    Private Function RetrieveSuperiorsLastNameCell( _
        ByVal employeeId As String) As DataGridViewCell
        For Each row As DataGridViewRow In DataGridView1.Rows
            If row.IsNewRow Then Return Nothing
            If row.Cells(ColumnName.EmployeeId.ToString()). _
                Value.ToString().Equals(employeeId) Then
                Return row.Cells(ColumnName.LastName.ToString())
        Next
        Return Nothing
    End Function
#Region "checkbox state"
    Dim inOffice As New Dictionary(Of String, Boolean)
    Private Sub DataGridView1_CellValuePushed(ByVal sender As Object, _
     ByVal e As DataGridViewCellValueEventArgs) _
        Handles DataGridView1.CellValuePushed
        If IsCheckBoxColumn(e.ColumnIndex) Then
            Dim employeeId As String = GetKey(e)
            If Not inOffice.ContainsKey(employeeId) Then
                inOffice.Add(employeeId, CType(e.Value, Boolean))
                inOffice.Item(employeeId) = CType(e.Value, Boolean)
    Private Function GetKey(ByVal cell As DataGridViewCellValueEventArgs) As String
        Return DataGridView1.Rows(cell.RowIndex).Cells( _
    End Function
    Private Sub DataGridView1_CellValueNeeded(ByVal sender As Object, _
        Handles DataGridView1.CellValueNeeded
                Dim defaultValue As Boolean = False
                inOffice.Add(employeeId, defaultValue)
            e.Value = inOffice.Item(employeeId)
    Private Function IsCheckBoxColumn(ByVal columnIndex As Integer) As Boolean
        Dim outOfOfficeColumn As DataGridViewColumn = _
            DataGridView1.Columns(ColumnName.OutOfOffice.ToString())
        If DataGridView1.Columns(columnIndex) Is outOfOfficeColumn Then
            Return True
            Return False
    End Function
#End Region
End Class
Hope this is of some use to you.
