Shell programming:
# comment
if (expr) command foreach var (wordlist)
command(s)
if (expr) then end
command(s)
endif
if (expr) then while (expr)
command(s) command(s)
else end
command(s)
endif
if (expr) then switch (str)
command(s) case pat1:
else if (expr) then command(s)
command(s) breaksw
else case pat2:
endif breaksw
default:
label: command(s)
... breaksw
goto label endsw
