Triage is supposed to make things simpler. In a lot of teams, it does the opposite.
When you can’t reach a confident verdict early, alerts turn into repeat checks, back-and-forth, and “just escalate it” calls. That cost doesn’t stay inside the SOC; it shows up as missed SLAs, higher cost per case, and more room for real threats to slip through.
So where does triage go wrong? Here are five triage
This is a companion discussion topic for the original entry at https://thehackernews.com/2026/02/top-5-ways-broken-triage-increases.html
