Try Catch Finally Exceptions
Try, Catch
Quick Example…
Dim a As String = "Hello World"
Dim b As Integer
   b = CInt(a)
Catch ex As Exception
   MsgBox(ex.ToString())
The above code will cause an “Exception” when it “Try”'s to make a an integer. (b = CInt(a))
It will be handled by the Try and Catch blocks in the code..
All you will recive is a MsgBox with the error discription, and the rest of the code will continue to run.
Different Exceptions
When you are making programs your not just dealing with regular Exceptions. There will be SqlException’s, InvalidCastException’s, and FileNotFoundException’s, among others… lots of others…
In our previous example we were really catching a InvalidCastException, because it is Invalid to make a string “Hello World” into an Integer.
We would then do the following..
Dim b As Integer
   b = CInt(a)
Catch ex As InvalidCastException
   MsgBox("I'm Sorry, but you can't do that..." & vbcrlf & vbcrlf & ex.Message)
System.Exception Main Members
If you noticed… in the last example I used ex.Message instead of ex.ToString()… the folowing are the main members or the System.Exception class and are used by all Exception’s in the .NET Framework
ex.HelpLink
   '(String) Gets or sets a link to the help file associated with this exception.
ex.InnerException
   '(System.Exception) Gets the System.Exception instance that caused the current exception.
ex.Message
   '(String) Gets a message that describes the current exception.
ex.Source
   '(String) Gets or sets the name of the application or object that causes the error.
ex.StackTrace
   '(String) Gets a string representation of the frames on the call stack at the time the current exception was thrown.
ex.ToString
   '(String) Creates and returns a string representation of the current exception.
Using Finally
You can also add Finally to your Try and Catch block to run code no matter what happens.
Dim b As Integer
Dim MyMessage As String
   b = CInt(a)
   MyMessage = "Sucessfully made the string 'a' to an integer in 'b'."
   MyMessage = "Could not make the string 'a' into an integer 'b'."
Finally
   MsgBox(MyMessage)
Ok… now lets look at that…
I added Dim MyMessage As String, to hold our message.
Then in the Try section of our block I added MyMessage = “Sucessfully made the string ‘a’ to an integer in ‘b’.”, This line will ONLY run if b = CInt(a) does NOT cause an exception.
Then in our Catch block we added MyMessage = “Could not make the string ‘a’ into an integer ‘b’.”, This line will ONLY run in b = CInt(a) DOES cause an exception.
We also added in Finally, This will always run.. weather there is an exception or not.
Using Multiple Catch’s
Of course everything is not an InvalidCastException (but everone is an Exception). So you can add multiple Catch statments to one Try.
Lets take a look… we are going to use a new example though, one for retreaving a SqlDataReader from an SQL Database
Dim strSQL As String
Dim SqlConn As Data.SqlClient.SqlConnection
Dim SqlComm As Data.SqlClient.SqlCommand
Dim DR As Data.SqlClient.SqlDataReader
Dim result As String = String.Empty
'Notice we declare our variables outside of the try block, this is so we can use it in the finally block.
    strSQL = "SELECT * FROM mytable WHERE mycol=23"
    SqlConn = New Data.SqlClient.SqlConnection("Persist Security Info=False;Data Source=__;Initial Catalog=__;User ID=__;Password=__;")
    SqlComm = New Data.SqlClient.SqlCommand(strSQL, SqlConn)
    SqlConn.Open()
    DR = SqlComm.ExecuteReader()
    If DR.Read() Then
        result = DR.Item("mycol") & "----" & DR.Item("mycol2")
        result = "No records found."
Catch ex As System.Data.SqlClient.SqlException
    'This will catch SQL statement Errors in your "SELECT" statement and Connectionstring.
    result = "There was an SqlException.." & vbCrLf & "Details..." & vbCrLf & ex.ToString()
    'This will catch Cast exceptions
    result = "There was an InvalidCastException..." & vbCrLf & "Details..." & vbCrLf & ex.ToString()
    'This will catch everything else. (except errors in the finally statement)
    result = "There was an Unhandled Exception..." & vbCrLf & "Details..." & vbCrLf & ex.ToString()
Finally
    'Make sure to use IsNothing or Is Nothing when in Finally,
    ' you will get "Object Reference" errors if you dont.
    If IsNothing(DR) = False Then
        If DR.IsClosed = False Then DR.Close()
    If IsNothing(SqlComm) = False Then SqlComm.Dispose()
    If IsNothing(SqlConn) = False Then
        If SqlConn.State <> Data.ConnectionState.Closed Then SqlConn.Close() : SqlConn.Dispose()
    MsgBox(result)
If you run the above code WITH OUT changing ANYTHING.. you will get a msgbox like below..
Details…
System.Data.SqlClient.SqlException: SQL Server does not exist or access denied.
at System.Data.SqlClient.SqlConnection.Open()
This is because “__” is probably not an sqlserver in your LAN.
