Check Registry Entry if it Exists
Anyone know of a better way of testing to see if a reg key exists? Currently I am just catching the nullreferenceexception and using that … but I would prefer a “exists” method or the like …
Anyway, here is what I am doing …
Imports Microsoft.Win32
Public Class cRegistry
    Public Shared Function TestForKey(ByVal Reg_Key_Path As String, _
                ByVal Reg_Value As String) As Boolean
        Dim s As String
        Dim reg_key As RegistryKey
        Dim reg_hive As RegistryHive
            reg_key = Registry.LocalMachine.OpenSubKey(Reg_Key_Path)
            If reg_key.ValueCount = 0 Then
                Return False
                Return True
        Catch nre As NullReferenceException
            Return False
        Catch e As Exception
            Throw New Exception("The following error occured while testing the Registry Key", e)
    End Function
End Class
