Original link
- Soft SPL - loaded to ram temporarily, erased after reboot, use it to flash HardSPL or tested working roms.
- Hard SPL - A version which is flashed to rom.
So, what`s this?
- Based on oxygen spl, but
- Doesn`t check CID
- KeyCard security is reset
- Allows to flash unsigned (custom) nbh files.
http://rapidshare.com/files/65732449/hspl.7z.html
Instructions:
- Copy spl.nb, spl.lnk and jumpspl.exe to the root of device, hold camera and launch spl.lnk - you`ll see the white screen
- Connect USB to pc
- From the flasher folder run ROMUpdateUtility.exe and follow instructions to flash the Hard-SPL if needed. or you can flash ANY oxygen rom
- After flashing Hard-Spl, to avoid reflashing, use
nbhextract ruu_signed.nbh
with any official update.it will dump the nbh. you`ll see some file like 00_OS.nb0 or 04_OS.nb0, any *_OS.nb0
use Htc Rom Tool (can be found on forum) and go to build rom, select OXYGEN, use 1.0.000.0 version, and go to system box, and press “…”
Load your os.nb0 and press build rom. then you can use this nbh to flash os. just replace original nbh file within updater directory.
