Sendmail on RH8 ( post #1)
Hi Gang,
This worked for me !!!
Change the following entries in the /etc/mail/sendmail.cf file…
$Id: accept_unresolvable_domains.m4,v 8.10 1999/02/07 07:26:07 gshapiro Exp $
local info
my LDAP cluster
need to set this before any LDAP lookups are done (including classes)
#D{sendmailMTACluster}$m
Cwlocalhost
file containing names of hosts for which we receive email
Fw/etc/mail/local-host-names
my official domain name
… define this only if sendmail cannot automatically determine your domain
CP.
“Smart” relay host (may be null)
DSsmtp.myipserver.com
Also do the following in the /etc/mail/access file :
Check the /usr/share/doc/sendmail/README.cf file for a description
of the format of this file. (search for access_db in that file)
The /usr/share/doc/sendmail/README.cf is part of the sendmail-doc
package.
by default we allow relaying from localhost…
mydomain.com RELAY
localhost.localdomain RELAY
localhost RELAY
127.0.0.1 RELAY
Enjoy!!!
P.S. Happy Holidays…
