Error Messages
Here we list a number of common errors that occur in C-shell scripts.
No match:
You probably forgot to quote a so-called shell meta character (one of * ? ( ) $ ), since the shell tried to use them as file wildcard expansion. A common example is
ants=*
which should have read
ants='*' or ants=\*
Undefined variable:
A (shell or environment) variable was never set. If you want, you can use a test to see if the variable really exists, and take appropriate actions:
if ($?var == 0) then
echo "Variable 'var' does not exist"
else
echo "Variable 'var' has the value $var"
endif
Expression Syntax:
Well, this could almost be anything. You probably need to run the script in verbose (-v) or echo (-x) mode to see where and how the syntax error came about. In checker mode the debug= keyword to the project command can be used to increase the output.
Badly formed number:
Numbers in the C-shell must be integers. So you cannot do @ a=1.1'' or if ( $lst > 10.5 ) echo $lst’'. Some simple floating point math can be done with the UNIX program bc or the Miriad program calc .
echo "1.2*sqrt(3)" | bc -l
calc "1.2*sqrt(3)"
Command not found:
You either misspelled the command, or you have the search path set wrong. Check the PATH environment or path shell variables (they are equivalent, a change in one will change the other).
